[mapguide-users] Re: Help me start develop with mapguide
Jamo adam.jamison at portbris.com.au
Mon Jun 28 01:13:57 EDT 2010
Where is the Vector / raster data coming from.
What is it's native / default format.
What is the purpose of your mapguide application?
many data formats are supported by default you may not need to do any data
conversion with your vector data.
Simply create a featuresource using maestro select the required FDO.
Then create a layer for your data.
Then create a map add your layer.
Then create a layout add your map.
Voila done.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Help-me-start-develop-with-mapguide-tp5203067p5229498.html
