[mapguide-users] Performance of MapGuide on a Virtual Server
Jason Birch
jason at jasonbirch.com
Tue Jun 29 22:09:22 EDT 2010
It's really hard to say. Have you done any profiling on the server to
determine whether you're disk/memory/cpu-bound? What do you mean by
close? What's the throughput of the network connection?
What version of mapguide are you running? What's your data source?
How many layers do you have in your map? Are you applying appropriate
display ranges for the data?
Virtualization can be a measurable performance factor, especially for
disk access or if your farm is experiencing heavy resource contention.
It's not necessarily the first place I'd look though. An optimized
map on a properly-resourced virtual machine shouldn't be
order-of-magnitude worse than the same on equivalent hardware.
Jason
On 2010-06-29, oshan <icycool at inbox.com> wrote:
> Hey Guys
> I am running mapguide on a virtual red hat Linux server.
> Specs:
> Intel(R) Xeon(R) CPU X5570 @ 2.93GHz
> RAM 3GB
> It take about 1 minute to load Ajaxviewer in firefox (cold start) and I am
> very close to the actual server. I have about 10 data sources. The map
> package is about 19MB.
> I am wondering if it will make a big difference to the performance if
> mapguide is moved to a dedicated server?
> Thanks
> Oshan
> http://osgeo-org.1803224.n2.nabble.com/Performance-of-MapGuide-on-a-Virtual-Server-tp5234442p5234442.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
