[mapguide-users] Session Repository to Library Repository?
Jason Birch jason at jasonbirch.com
Wed Jun 30 10:23:37 EDT 2010
After you have saved your web layout, right click on it in the Fusion
navigation tree and copy its resource ID to the clipboard. Use this
value (it should start with Library://) for the WEBLAYOUT= part of
your URL, and remove the SESSION= part of the URL entirely.
On 2010-06-30, Edu M. <etm at sapo.pt> wrote:
> thank you,
> but i'm not a programmer and i just want finisht the session expired
> problem, and I read that the problem is because i'm using session URL and
> not library and I do not know what to do
> Regards
> Edu
> http://osgeo-org.1803224.n2.nabble.com/Session-Repository-to-Library-Repository-tp5237566p5237757.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
