[mapguide-users] Maestro Api runtime map selection
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Wed Mar 3 03:05:21 EST 2010
Unfortunately the MaestroAPI cannot create datastores,
or update/insert features because this is not exposed in the MapGuide
http API.
You have to use the MapGuideDotNetApi.dll or similar to access those
functions.
As a workaround, you can instead use an SQLite database, which you can
create
and upload to a FeatureSource. This enables you to control the database
layout,
and also allows you to connect to the database with standard tools
(such as ODBC or System.Data.IDbConnection), for updates and inserts.
There seems to be a bug regarding Selections (selection support was
introduced recently).
You can get the selection this way until the bug is fixed:
selection = new OSGeo.MapGuide.MaestroAPI.Selection(rtMap,
rtMap.CurrentConnection.GetSelectionXml(rtMap.ResourceID));
This should also reveal how to get the selection document directly.
The ToString() function is not overloaded, so when using the selection
object you have to use ToXml() instead.
I will fix this too.
Regards, Kenneth Skovhede, GEOGRAF A/S
On 02-03-2010 21:57, Jamo wrote:
> Ok I started creating a class of my own that would produce a layer definition
> and save it to the repository...
> Got upto the point of creating vector scale ranges and thought ..... Dang
> this has already been done.
> Enter --> Maestro Api.
> Is this the correct place to be asking about the maestro api?
> Can maestro Api create an SDF data store ? with actual SDF data file ....?
> Can maestro Api write features to the SDF data store ?
> It looks like It can do everything else I need.
> prepare a new layerdefinition and add it to the map. (and save it to the
> library if the user requires)
> grab existing layer definition amend it and save it back.
> I've been requested to improve my markup tools to include more variety, at
> the moment users can just draw a red line draw a red polygon and place a red
> ricle ..... very bland.
> I'm suggesting maybe to produce a dialog that lets the user choose all the
> style options themselves. then save it as a vectorscale range and filter it
> with style = 1, style =2 on the actual elements...
> I'm just trying some basic maestro commands and the below code returns no
> selection (blank featureset) ....
> Have I got the real instance of the runtime map?
> Uri host = new Uri(mapagent);
> ServerConnectionI conn = new HttpServerConnection(host, sessionId, "en",
> true);
> ResourceIdentifier res = new
> ResourceIdentifier("PortBris",ResourceTypes.RuntimeMap,sessionId);
> RuntimeMap rtMap = conn.GetRuntimeMap(res.ResourceId);
> Response.Write(rtMap.Selection);
