[mapguide-users] Re: Redline Text
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Thu Mar 4 05:57:25 EST 2010
You should use a click tool.
If you use the Ajax viewer, the function is called DigitizePoint,
not sure what the equivalent is in Fusion, but you can load some
MapGuide compatibility script if you can't find the right one.
In the callback handler you will get the x/y value of the point that
the user has clicked (in mapping coordinate system (MCS) values).
You then need to send the value to the server, using AJAX or a form post
or similar.
On the server, if you have a database, simply insert the record as you
would normaly,
using an SQL INSERT statement.
If you are not using a database (or want to support multiple datasource
types), you can
use the MapGuide MgUpdateFeatures functions:
http://www.osgeo.org/files/mapguide/docs/webapi/d5/d10/class_mg_feature_service_278b25e5af6145f091457701fec788dd.htm#278b25e5af6145f091457701fec788dd
And specifically:
http://www.osgeo.org/files/mapguide/docs/webapi/d4/d63/class_mg_insert_features.htm
Regards, Kenneth Skovhede, GEOGRAF A/S
On 04-03-2010 09:14, Twi wrote:
> I have a datasource with a layer that looks
> my annotations.
> The problem how to liaison between the click of
> the user and insert the annotation database?
> Thank you
