[mapguide-users] ForegroundColor from FDO property
Traian Stanev traian.stanev at autodesk.com
Wed Mar 10 15:04:44 EST 2010
Can you describe what exactly you did when you "manually edited xml"?
Traian
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of David Hequet
Sent: Wednesday, March 10, 2010 5:23 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] ForegroundColor from FDO property
When you create a mapguide layer, you can set some symbolization using FDO
properties (eg: set a point angle from the "Rotation" column from an oracle
table, line thickness...).
Is theyr a way to set text symbolization like foreground color using
properties? I tried to do it manualy by editing xml. Not working, but maybe
someone has an idea?
Thank you,
David
View this message in context: http://n2.nabble.com/ForegroundColor-from-FDO-property-tp4708122p4708122.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
