[mapguide-users] RE: ForegroundColor from FDO property
Traian Stanev traian.stanev at autodesk.com
Thu Mar 11 15:04:19 EST 2010
I looked at the code and it seems like you can use an FDO property, but not string property -- the property has to evaluate to an integer. So it should work if you convert the hex string to an integer.
Traian
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of David Hequet
Sent: Thursday, March 11, 2010 4:02 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] RE: ForegroundColor from FDO property
oh sorry:
juste try to edit xml with maestro to have
            <Fill>
              <FillPattern>Solid</FillPattern>
              <ForegroundColor>myFdoProperty</ForegroundColor>
              <BackgroundColor>FF000000</BackgroundColor>
            </Fill>
instead of:
            <Fill>
              <ForegroundColor>FF000000</ForegroundColor>
            </Fill>
where "myFdoProperty" is a string column containing hex color (eg:
FFEFEFEF...)
David
View this message in context: http://n2.nabble.com/ForegroundColor-from-FDO-property-tp4708122p4714824.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
