[mapguide-users] RE: ForegroundColor from FDO property
Traian Stanev traian.stanev at autodesk.com
Fri Mar 12 10:21:12 EST 2010
Double or Int64 won't work, it has to be Int32, or you have to make your color expression in the XML include an explicit cast to Int32, like this:
ToInt32(myInt64FdoProperty)
FDO expressions are strongly typed. Sometimes unnecessarily so. :)
Traian
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of David Hequet
Sent: Friday, March 12, 2010 4:56 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] RE: ForegroundColor from FDO property
Thanks! It works!
Note: the FDO property containing the "integered" color must be a string
property type.
I tried with double or int64 property type, doesn't work.
David
View this message in context: http://n2.nabble.com/ForegroundColor-from-FDO-property-tp4708122p4721339.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
