[mapguide-users] Re: Zoom+select features problem
Mauricio Villablanca
mgvillablanca at yahoo.com
Sat Mar 13 16:33:24 EST 2010
You need to properly separate your server-side code from the client-sided
code. In your code, the first line of PHP is
<?php echo $selectionXml;?>
which will fail since the variable hasn't even been defined yet.
I suggest you check a book on PHP development. Having said that, this is
what your code should look like:
<?php
include 'utilityfunctions.php';
try {
$webconfigDirectory = $webExtensionsDirectory . 'www\\';
$webconfigFilePath = $webconfigDirectory . 'webconfig.ini';
MgInitializeWebTier($webconfigFilePath);
$args = ($_SERVER['REQUEST_METHOD'] == "POST") ? $_POST : $_GET;
$sessionId = $args['SESSION'];
$mapName = $args['MAPNAME'];
$userInfo = new MgUserInformation($sessionId);
$siteConnection = new MgSiteConnection();
$siteConnection->Open($userInfo);
$resourceService =
$siteConnection->CreateService(MgServiceType::ResourceService);
$featureService =
$siteConnection->CreateService(MgServiceType::FeatureService);
$map = new MgMap();
$map->Open($resourceService, 'map');
$layers = $map->GetLayers();
$count = $layers->GetCount();
for ($i = 0; $i < $count; $i++) {
$layer = $layers->GetItem($i);
$layerClassName1 = $layer->GetFeatureClassName();
$FeatureResId = new
MgResourceIdentifier("Library://data/resource.FeatureSource");
$queryOptions = new MgFeatureQueryOptions();
$val="PARCEL";
$val1="44142300003000";
$query=$val . "=" . $val1;
$queryOptions->SetFilter($selectionString);
$featureReader = $featureService->SelectFeatures($FeatureResId,
$layerClassName1, $queryOptions);
$featureReader->ReadNext();
$featureAgfGeometry = $featureReader->GetGeometry('Geometry');
$agfReaderWriter = new MgAgfReaderWriter();
$featureGeometry = $agfReaderWriter->Read($featureAgfGeometry);
$centroid = $featureGeometry->GetCentroid();
$mapCenterX = $centroid->GetCoordinate()->GetX();
$mapCenterY = $centroid->GetCoordinate()->GetY();
$selection = new MgSelection($map);
$selection->AddFeatures($layer, $featureReader, 1);
$selectionXml = $selection->ToXml();
catch (MgException $e)
echo "<p><strong>Error:</strong> ";
echo $e->GetDetails();
echo "</p>";
<html>
<head>
<title>Zoom Feature</title>
<meta content="text/html; charset=utf-8" http-equiv="Content-Type">
<meta http-equiv="content-script-type" content="text/javascript">
<meta http-equiv="content-style-type" content="text/css">
<link href="../styles/globalStyles.css" rel="stylesheet"
type="text/css">
<link href="../styles/otherStyles.css" rel="stylesheet" type="text/css">
<script language="javascript">
function Zoom1(x,y) {
var xval=x;
var yval=y;
parent.parent.mapFrame.ZoomToView(xval, yval, 2000, true);
function Zoom() {
selectionXml = '<?php echo $selectionXml;?>';
parent.parent.mapFrame.SetSelectionXML(selectionXml);
</script>
</head>
<body>
<input type="text" name="id" size="15">
<input type="button" name="button" value="Click" size="10"
onclick="Zoom1(<?php echo $mapCenterX;?>,<?php echo $mapCenterY;?>)">
<input type="button" name="button1" value="Select" size="10"
onclick="Zoom()">
</body>
</html>
Regarding the second question, how about taking the code in your Zoom
function and putting it in the other function? :)
View this message in context: http://n2.nabble.com/Zoom-select-features-problem-tp4708107p4729119.html
