[mapguide-users] View maps in standard MapViewerPHP not Fusion
Chris Claydon chris.claydon at autodesk.com
Tue Mar 16 12:05:37 EDT 2010
An "ApplicationDefinition" resource defines a Fusion-based flexible web layout. If you want to use the basic viewer, you need to create a "WebLayoutDefinition" corresponding to a basic web layout.
Chris.
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of shepwaydistrictcouncil
Sent: Tuesday, March 16, 2010 9:39 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] View maps in standard MapViewerPHP not Fusion
We have created a demo that we access internally via the following URL:
http://xxxx:8008/mapguide2010/fusion/templates/mapguide/maroon/index.html?ApplicationDefinition=Library%3a%2f%2fLayers%2fboundary.ApplicationDefinition
We want to be able to try this using the standard /mapviewerphp/ code (not
fusion) but everything we try doesn't work, are we missing something simple
or do we need to publish the layers in a different place or do I need to
alter a config file somewhere?
Kind regards
Neil
View this message in context: http://n2.nabble.com/View-maps-in-standard-MapViewerPHP-not-Fusion-tp4744399p4744399.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
