[mapguide-users] Re: (1092688208) Resource was not found:
Library://Samples/Layouts/Sample.WebLayout
kfwebb at bombasticlocution.com
Mon Mar 22 20:52:54 EDT 2010
Thank you for your reply Jackie.
Yes - display_errors = On is set.
And it did reveal more information that I was initially scrolling past
in the Apache error log.
This was the cause of the Internal Server error.
(46912498596224) DefaultDir:
"/opt/Autodesk/mapguideenterprise2010/share/gis/coordsys" is not a
directory! Install the Coordinate System library into this directory or
set MENTOR_DICTIONARY_PATH to where they are currently installed.
(46912498596224) MgCoordinateSystemInitializationFailedException caught
in CCoordinateSystemCatalog constructor - The coordinate system
initialization failed.
Even though msgerver.sh has an export line for
MENTOR_DICTIONARY_PATH=/usr/local/mapguideopensource/share/gis/coordsys .
I corrected this error by copying the contents of
to
Investigation continues ...
KFW
On Mon, 2010-03-22 at 15:11 -0800, Jackie Ng wrote:
> Have you set display_errors = On in your php.ini? It may reveal more
> information.
> - Jackie
