[mapguide-users] Re: Response text error in Getting layer
properties
Zac Spitzer
zac.spitzer at gmail.com
Fri Mar 26 11:04:53 EDT 2010
Can you share the actual variables? You should be able to write a test to
confirm they work. Only certain parameters can throw that error
On 27 Mar 2010 01:58, "padmini godavarthi" <godavarthi.padmini at gmail.com>
wrote:
Hi ,
iam passing the following parameters
reqParams = "COMMAND=GETLAYERPROPERTIES";
reqParams += "&SESSION=" + encodeURIComponent(session)...
for test purpose,i put a alert box overhere. in this all params
command,sessionid,mapname and layername (property)are passing corectly...
Regards,
Padmini G.
View this message in context:
http://n2.nabble.com/Response-text-error-in-Getting-layer-properties-tp4802751p4804379.html
___________________________________...
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20100327/2d485a0a/attachment.html
