[mapguide-users] building 64bit openmapguide on rhel 5.4
Trevor Wekel
trevor_wekel at otxsystems.com
Tue Mar 30 11:16:33 EDT 2010
Are you compiling against trunk? The 2.1 branch will probably not compile on 64 bit.
Some of the third party projects still require atomic.h. Please reference http://trac.osgeo.org/mapguide/wiki/CompilingMapGuide22. This may correct AtomicDecrement and AtomicIncrement. Try using the default png and png-devel libraries from RHEL5.4. This may correct png_check_sig.
Regards,
Trevor
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of adamb at geoform.hu
Sent: March 30, 2010 7:16 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] building 64bit openmapguide on rhel 5.4
Dear fellows,
Our office have a 64bit rhel 5.4 linux machine, that I want to use (among
others) for openmapguide. I passed through fdo install, and build_oem.sh.
I downloaded some third party libraries newer then what was provided in
the tarball (namely: libpng, libjped, freetype and agg) Otherwise it's
clean and tidy. Now I faced errors during build, that I cannot resolve
alone. Can anyone help, please? Adam
/usr/local/src/MgDev/Oem/DWFTK7.1/develop/global/src/dwf/.libs/libdwftk:
undefined reference to `DWFCore::AtomicDecrement(int volatile*)'
undefined reference to `DWFCore::AtomicIncrement(int volatile*)'
/usr/local/src/MgDev/Common/Renderers/.libs/libMgRenderers.so: undefined
reference to `png_check_sig'
undefined reference to `DWFCore::DWFTimer::Tick64()'
reference to `png_set_gray_1_2_4_to_8'
/usr/local/src/MgDev/Oem/DWFTK7.1/develop/global/src/dwfcore/.libs/libdwfcore:
undefined reference to `DWFCore::DWFTimer::Tick32()'
collect2: ld returned 1 exit status
make[3]: *** [mgserver] Error 1
make[3]: Leaving directory `/usr/local/src/MgDev/Server/src/Core'
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory `/usr/local/src/MgDev/Server/src'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/usr/local/src/MgDev/Server'
make: *** [all-recursive] Error 1
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
