[mapguide-users] Re: re: google mapintegration with mapguide
Kori Maleski
kori.maleski at gmail.com
Tue Mar 30 11:24:15 EDT 2010
To work around the Overview map projection issue do the following:
O
On line 110 of OverviewMap.js, add the following 2 lines:
this.mapObject.projection = this.getMap().oMapOL.getProjection()
this.mapObject.oLayerOL.projection =
This will alllow the overview to support whatever projection your main map
is in.
The overview map is only a single layer - the MapGuide layers being the
single layer. It doesn't allow a MapGuide and Google layer at the same time
without some coding (someone correct me if I am off base). I fiddled with
the code and got the Google layer in, but haven't got it working quite
properly. Need more spare time.
Cheers,
Kori Maleski
On Tue, Mar 30, 2010 at 3:48 AM, Jose Cerrejon <gis at mapas-sll.com> wrote:
> I have the same issue now. Maybe is a bug in fussion.
> http://n2.nabble.com/re-google-mapintegration-with-mapguide-tp3049773p4823732.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20100330/d53907ef/attachment.html
