[mapguide-users] building 64bit openmapguide on rhel 5.4 - Found
word(s) list error in the Text body [Keyword]
Balogh Ádám
adamb at geoform.hu
Wed Mar 31 03:22:00 EDT 2010
Dear Rajeev,
I work on this compilation for the second week now, I still haven't given
up. Once I manage doing it I will send a step-by-step storyboard of building
mapguide opensource on 64 bit Linux. Thank you for sharing your experience.
I will probably start from the beginning again, as Trevor suggested,
checking out source from svn...
Regards,
Adam
----- Original Message -----
To: "MapGuide Users Mail List" <mapguide-users at lists.osgeo.org>
Cc: <adamb at geoform.hu>
Sent: Tuesday, March 30, 2010 8:07 PM
Subject: RE: [mapguide-users] building 64bit openmapguide on rhel 5.4 -
Found word(s) list error in the Text body [Keyword]
> Adam,
> I will be grateful if you could share your learnings on 64 bit build. I
> tried with 2.0.2 (the one downloadable) and though after herculean efforts
> I
> managed to compile stuff (mix-match etc etc), the final thing did not run
> (it went into some weird loop - 100% cpu, mem consumption - so much so
> that
> I could barely kill the process)
> thanks
> rajeev
> Rajeev K. Singh
> IntelliPlanner Software Systems, Inc.
> West Windsor, NJ (USA) / New Delhi (India)
> +1.609.945.4927 (o) / +1.203.558.3224 (c)
> +91.11.4672 6635(o) / +91.995 841 1064(c)
> This mail contains proprietary and confidential information.
> Please destroy it if you received it by mistake and notify the sender.
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org]On Behalf Of Trevor Wekel
> Sent: 30 March 2010 11:17
> To: MapGuide Users Mail List
> [Keyword]
> Are you compiling against trunk? The 2.1 branch will probably not compile
> on 64 bit.
> Some of the third party projects still require atomic.h. Please reference
> http://trac.osgeo.org/mapguide/wiki/CompilingMapGuide22. This may correct
> AtomicDecrement and AtomicIncrement. Try using the default png and
> png-devel libraries from RHEL5.4. This may correct png_check_sig.
> Regards,
> Trevor
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of
> adamb at geoform.hu
> Sent: March 30, 2010 7:16 AM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] building 64bit openmapguide on rhel 5.4
> [Keyword]
> Dear fellows,
> Our office have a 64bit rhel 5.4 linux machine, that I want to use (among
> others) for openmapguide. I passed through fdo install, and build_oem.sh.
> I downloaded some third party libraries newer then what was provided in
> the tarball (namely: libpng, libjped, freetype and agg) Otherwise it's
> clean and tidy. Now I faced errors during build, that I cannot resolve
> alone. Can anyone help, please? Adam
> /usr/local/src/MgDev/Oem/DWFTK7.1/develop/global/src/dwf/.libs/libdwftk:
> undefined reference to `DWFCore::AtomicDecrement(int volatile*)'
> undefined reference to `DWFCore::AtomicIncrement(int volatile*)'
> /usr/local/src/MgDev/Common/Renderers/.libs/libMgRenderers.so: undefined
> reference to `png_check_sig'
> undefined reference to `DWFCore::DWFTimer::Tick64()'
> reference to `png_set_gray_1_2_4_to_8'
> /usr/local/src/MgDev/Oem/DWFTK7.1/develop/global/src/dwfcore/.libs/libdwfcor
> e:
> undefined reference to `DWFCore::DWFTimer::Tick32()'
> collect2: ld returned 1 exit status
> make[3]: *** [mgserver] Error 1
> make[3]: Leaving directory `/usr/local/src/MgDev/Server/src/Core'
> make[2]: *** [all-recursive] Error 1
> make[2]: Leaving directory `/usr/local/src/MgDev/Server/src'
> make[1]: *** [all-recursive] Error 1
> make[1]: Leaving directory `/usr/local/src/MgDev/Server'
> make: *** [all-recursive] Error 1
> mapguide-users mailing list
