[mapguide-users] Re: re: google mapintegration with mapguide
Kori Maleski kori.maleski at gmail.com
Wed Mar 31 11:43:52 EDT 2010
Insert the code fix right above the "var options = {" in the loadOverview
like so:
loadOverview: function(layer)
        if (this.control) {
          this.control.destroy();
        var size = $(this.domObj).getContentBoxSize();
        this.oSize = new OpenLayers.Size(size.width, size.height);
        if (!layer) {
            layer = this.getMap().oMapOL.baseLayer.clone();
        layer.isBaseLayer = true;
        layer.ratio = 1.0;
        if (layer.singleTile) {
          this.oMapOptions.numZoomLevels = 3;  //TODO: make this configurable?
        this.mapObject.projection = this.getMap().oMapOL.getProjection()
	this.mapObject.oLayerOL.projection = this.getMap().oMapOL.getProjection()
        var options = {
          div: this.domObj,
          minRatio: this.nMinRatio,
          maxRatio: this.nMaxRatio,
          mapOptions: this.oMapOptions,
          layers: [layer]
        this.control = new OpenLayers.Control.OverviewMap(options);
        if (size.width == 0 || size.height == 0) {
          return;   //don't try to load if the container is not visible
        } else {
          this.getMap().oMapOL.addControl(this.control);
          this.bDisplayed = true;
        //console.log('OverviewMap mapLoaded');
Cheers,
Kori Maleski
On Tue, Mar 30, 2010 at 11:56 PM, Jose Cerrejon <gis at mapas-sll.com> wrote:
> I've tried the fix, but with the last SVN, doesn't works (03/31/2010). This
> is the code in the line 110:
> 110 var options = {
> 111          div: this.domObj,
> 112          size: this.oSize,
> 113          minRatio: this.nMinRatio,
> 114          maxRatio: this.nMaxRatio,
> 115          mapOptions: this.oMapOptions,
> 116          layers: [layer]
> 117        };
> http://n2.nabble.com/re-google-mapintegration-with-mapguide-tp3049773p4829338.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20100331/bf445065/attachment.html
