[mapguide-users] Re: How to use setselection in fusion?
miansi
AndreiSinelnikov at SierraSystems.com
Wed May 5 12:21:14 EDT 2010
That is what I am trying to do right now. I am working with .NET. So I will
share what I am doing and maybe that will help :-)
1. Build Selection XML
Note: searchString is your query (ID==1 || ID==2).
var mgMapName = requestParams["mapName"];
var mgSessionId = requestParams["sessionId"];
// Initialize the web-tier.
var realPath =
this.Request.ServerVariables["APPL_PHYSICAL_PATH"];
var configPath = realPath + "..\\webconfig.ini";
MapGuideApi.MgInitializeWebTier(configPath);
// Connect to the site.
var userInfo = new MgUserInformation(mgSessionId);
var conn = new MgSiteConnection();
conn.Open(userInfo);
// get the map
var map = new MgMap(conn);
map.Open(mgMapName);
// Perform any necessary transforms on the layer name or ids
var mapObjects =
TransformInputLayer(requestParams["objectTypes"].Split(','),
requestParams["objectIds"].Split(','));
// Select the objects on the map
var layers = map.GetLayers();
var selection = new MgSelection(map);
foreach (var layer in layers)
var searchString = new StringBuilder();
// Build out the search expression for the map layer
foreach (var mapObject in mapObjects.Where(rec =>
rec.LayerName == layer.Name))
if (searchString.Length > 0)
searchString.Append(" OR ");
searchString.AppendFormat("Id = '{0}'",
mapObject.ObjectId);
// Execte the search on the layer
var displayIdQuery = new MgFeatureQueryOptions();
displayIdQuery.SetFilter(searchString.ToString());
var featureReader =
layer.SelectFeatures(displayIdQuery);
selection.AddFeatures(layer, featureReader,
AppSettings.MgSelectionFilterSize);
featureReader.Close();
featureReader.Dispose();
var selectionXml = selection.ToXml();
map.Dispose();
2. Now the fun part I am working on right now - pass your selection to
Fusion.
I used to have AJAX Viewer and I used following logic:
I have some aspx page (SetMapSelection.aspx)
SetMapSelection.aspx:
<head runat="server">
<title>Set Map Selection Page</title>
<script type="text/javascript" language="javascript"
src="http://localhost/mapguide/fusion/layers/MapGuide/MapGuideViewerApi.js"></script>
<script type="text/javascript">
// Emit the following function and assocate it with the onLoad event for
// the page so that it gets executed when this page loads in the
browser.
// The function calls the SetSelectionXML method on the Viewer Frame,
// which updates the current selection on the viewer and the server.
function OnPageLoad() {
var selectionXml =
document.getElementById("hfSelectionXml").getAttribute("value");
parent.SetSelectionXML(selectionXml);
parent.ExecuteMapAction(10);
parent.ExecuteMapAction(99);
</script>
</head>
<body onload="OnPageLoad()">
<form id="formM5Logic" runat="server">
<div>
<asp:TextBox ID="hfSelectionXml" runat="server"></asp:TextBox>
<asp:HiddenField ID="HiddenFieldM5Logic"
runat="server"></asp:HiddenField>
</div>
</form>
</body>
SetMapSelection.aspx.cs:
protected void Page_Load(object sender, EventArgs e)
// Disable the client side cache
this.Response.Cache.SetCacheability(HttpCacheability.NoCache);
// Write to session which page is loaded, this is used by the
context help to determine the
// approproiate help page to load.
this.Session.Add(SessionStateBase.HELP_PAGE_REFERENCE,
this.Request.Path);
// Get the input parameters into the selection
var requestParams = this.Request.HttpMethod == "GET" ?
this.Request.QueryString : this.Request.Form;
var realPath =
// get the map
var mapObjects =
var featureReader =
map.Dispose();
this.hfSelectionXml.Text = selectionXml;
So as you can see - Page_Load builds selection XML and OnPageLoad passes it
to AJAX Viewer frame for further processing.
What I am puzzled with is to how to get a reference to Fusion, so I can pass
my selection to Fusion. Something like this:
var selectionXml =
var vf = top.document.getElementById('frmMap');
vf.document.forms[0].GetFusionMapWidget.setSelection(selectionXml,
true);
Note:
In my app I have 2 iframes - Map Viewer and Application frame. frmMap is Map
Viewer frame:
<iframe name="frmDefault" id="frmDefault" class="frameBoxGeneral"
frameborder="0" src="Pages/Loading.aspx">
</iframe>
<iframe name="frmMap" id="frmMap" src="<%= AppSettings.MgServicesUrl
%>/fusion/templates/mapguide/standard/index.html"
class="frameBoxMap" frameborder="0"></iframe>
View this message in context: http://osgeo-org.1803224.n2.nabble.com/How-to-use-setselection-in-fusion-tp5001965p5009766.html
