[mapguide-users] Re: Partial transparent selection color of the Ajax viewer
Jason Birch jason at jasonbirch.com
Fri May 7 12:10:21 EDT 2010
The selection transparency levels for selection are hard-coded:
http://trac.osgeo.org/mapguide/browser/trunk/MgDev/Common/Stylization/SE_Renderer.cpp#L135
http://trac.osgeo.org/mapguide/browser/trunk/MgDev/Common/Renderers/GDRenderer.cpp#L1537
http://trac.osgeo.org/mapguide/browser/trunk/MgDev/Common/Renderers/AGGRenderer.cpp#L1410
I believe that this is because it's generally desirable for the line to be
darker than the fill.  I guess that there are a couple options here; either
define a desirable alpha offset for the line, or create a second parameter
for the line fill colour.  A (harder) third option, but one which I would
personally prefer, would be to allow setting a SymbolDefinition for the
selection.
There are enhancement ticket requesting this change, but nobody's stepped up
with a solution yet:
http://trac.osgeo.org/mapguide/ticket/852
http://trac.osgeo.org/mapguide/ticket/416
Jason
On 7 May 2010 01:18, Julien Leture wrote:
> So, like the wiki said, the alpha value does not have any impact on the
> transparency. It's mean that 0x0000FFFF, 0x0000FF00 or 0x0000FF80 will
> generate the same selection overlay.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20100507/dd25a992/attachment.html
