[mapguide-users] (no subject)
Berdel, Brian brian.berdel at mcmtrans.com
Fri May 7 17:31:44 EDT 2010
Here is a sample Symbol Def file that will show flow directions with ">".  You have to edit the layer def's XML though.
<SimpleSymbolDefinition xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:noNamespaceSchemaLocation="SymbolDefinition-1.1.0.xsd" version="1.1.0">
    <Name>SanpipeFlow</Name>
      <Graphics>
        <Path>
          <Geometry> M 0.0, 0.0 L 20.0,0.0</Geometry>
          <LineColor>FF00d5d5</LineColor>
          <LineWeight>.2</LineWeight>
          <LineCap>'Round'</LineCap>
          <LineJoin>'Round'</LineJoin>
        </Path>
        <Text>
          <Content>'>'</Content>
          <FontName>'Arial'</FontName>
          <Height>6</Height>
          <PositionX>10</PositionX>
          <PositionY>0</PositionY>
          <HorizontalAlignment>'Center'</HorizontalAlignment>
          <VerticalAlignment>'Halfline'</VerticalAlignment>
          <TextColor>FF00d5d5</TextColor>
        </Text>
         </Graphics>
      <LineUsage>
        <VertexControl>'OverlapWrap'</VertexControl>
        <Repeat>20</Repeat>
      </LineUsage>
      <ParameterDefinition/>
</SimpleSymbolDefinition>
Brian  Berdel
McMahon Associates, Inc.
p: 215.283.9444 x 260
www.mcmtrans.com
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of binod_tripathy at yahoo.co.in
Sent: Friday, May 07, 2010 4:34 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] (no subject)
Hi Berdel,
If u have done this sucessfully
Could u please give the code for the SymbolDefinition
I have some sample SymbolDefinition files and I can apply to a layer
But How can i show the flow direction?
With a Arrow mark or any other style ?
Please,
I m trying it so long but didnot get any sucess
thanks
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
Important notice to recipients:
Copies of documents that may be relied upon by you are limited to the printed copies (also known as 'hard copies') that are signed and sealed by the Engineer and/or Land Surveyor. Files in electronic formats, or other types of information furnished by the Engineer and/or Land Surveyor to you such as text, data or graphics are for your convenience only. Any conclusions or information obtained or derived from such electronic files will be at the user's sole risk. When transferring documents in electronic formats, the Engineer and/or Land Surveyor makes no representation as to long-term compatibility, usability, or readability of the documents resulting from the use of software application packages, operating systems or computer hardware differing from those used by McMahon Associates, Inc. at the beginning of the project.
