[mapguide-users] Map/Legend refresh after
MgResourceService.SetResource (Fusion)
miansi
AndreiSinelnikov at SierraSystems.com
Tue May 11 22:06:17 EDT 2010
Hello,
Finishing move from AJAX viewer to Fusion Viewer.
Almost :-) everything work fine but refreshing map during runtime layer
creation.
Logic:
/// <summary>
/// Permanently Add Thematic Layer to Map
/// </summary>
internal void AddThematicLayerToMap(ThematicLayerInfo
thematicLayerInfo)
var resourceService =
(MgResourceService)this.MgConn.CreateService(MgServiceType.ResourceService);
var layerName = String.Format(
"{0}-{1}-{2}", thematicLayerInfo.ThematicLayerName.Replace("
", String.Empty), thematicLayerInfo.AttributeField, Guid.NewGuid());
var resourceId =
String.Format(this.Attributes.MgThemeSourceName, thematicLayerInfo.Network,
layerName);
var resourseLayer = new MgResourceIdentifier(resourceId);
resourceService.SetResource(resourseLayer, new
MgByteReader(thematicLayerInfo.LayerDefString, MgMimeType.Xml), null);
var resourceMap = new
MgResourceIdentifier(this.Attributes.MgMapName);
var xmlMap = Helper.GetMapXml(
resourceService,
resourceMap,
resourseLayer,
layerName,
thematicLayerInfo.ThematicLayerName + " - " +
Utility.FormatAttributeText(thematicLayerInfo.AttributeField),
true,
null);
resourceService.SetResource(resourceMap, new
MgByteReader(xmlMap, MgMimeType.Xml), null);
Basically if I refresh the page (IE8) - I will see added layer on the legend
and on the map, but it is not happening without refresh.
In any other area of the application where I use SetResource - map and
legend gets refreshed.
As you can see I use same resource service for saving layer and map. I tried
new instance of resource service - no luck. I tried UpdateRepository -
always getting exception about wrong resourse type, I tried at the end of
method to do following logic:
var map = new MgMap(this.MgConn);
map.Open(this.Attributes.MapName);
// Save map
map.Save();
No luck...
I updated C:\Program Files
(x86)\OSGeo\MapGuide\Web\www\fusion\layers\MapGuide\MapGuideViewerApi.js to
include following method:
function Reload() {
//var Fusion = window.top.Fusion;
var mapWidget = Fusion.getWidgetById(mgApiMapWidgetId);
if (mapWidget && mapWidget.isMapLoaded()) {
mapWidget.reloadMap();
mapWidget.redraw();
And calling it at the end...
So, right now completely out of ideas... Well... As a last method I can
submit frame instead of calling Reload, but page will flash and I do not
want it.
Maybe somebody can point me in the right direction?
Thank you!
Andrei
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Map-Legend-refresh-after-MgResourceService-SetResource-Fusion-tp5039258p5039258.html
