[mapguide-users] Re: create redline line and polygon using king fdo and MGOS
siva4gis leo.shiv at gmail.com
Sat May 15 04:20:23 EDT 2010
Hi Haris,
By using oracle custom data types you can save line,polygon directly in
oracle and you can see it in mapguide.
OracleArrayTypeFactory.cs
using System;
using Oracle.DataAccess.Types;
using Oracle.DataAccess.Client;
namespace Oracle.UdtBase
  public abstract class OracleArrayTypeFactoryBase<T> :
IOracleArrayTypeFactory
    public Array CreateArray(int numElems)
      return new T[numElems];
    public Array CreateStatusArray(int numElems)
      return null;
OracleCustomTypeBase.cs
using System;
  public abstract class OracleCustomTypeBase<T> : INullable,
IOracleCustomType, IOracleCustomTypeFactory
  where T : OracleCustomTypeBase<T>, new()
    private static string errorMessageHead = "Error converting Oracle User
Defined Type to .Net Type "+ typeof(T).ToString()+ ", oracle column is null,
failed to map to . NET valuetype, column ";
    private OracleConnection connection;
    private IntPtr pUdt;
    private bool isNull;
    public virtual bool IsNull
      get
        return isNull;
    public static T Null
      get
        T t = new T();
        t.isNull = true;
        return t;
    public IOracleCustomType CreateObject()
      return new T();
    protected void SetConnectionAndPointer(OracleConnection _connection,
IntPtr _pUdt)
      connection = _connection;
      pUdt = _pUdt;
    public abstract void MapFromCustomObject();
    public abstract void MapToCustomObject();
    public void FromCustomObject(OracleConnection con, IntPtr pUdt)
      SetConnectionAndPointer(con, pUdt);
    public void ToCustomObject(OracleConnection con, IntPtr pUdt)
    protected void SetValue(string oracleColumnName, object value)
      if (value != null)
        OracleUdt.SetValue(connection, pUdt, oracleColumnName, value);
    protected void SetValue(int oracleColumn_Id, object value)
      if (value != null)
        OracleUdt.SetValue(connection, pUdt, oracleColumn_Id, value);
    protected U GetValue<U>(string oracleColumnName)
      if (OracleUdt.IsDBNull(connection, pUdt, oracleColumnName))
        if (default(U) is ValueType)
          throw new Exception(errorMessageHead + oracleColumnName.ToString()
+ " of value type " + typeof(U).ToString());
        else
          return default(U);
      else
        return (U)OracleUdt.GetValue(connection, pUdt, oracleColumnName);
    protected U GetValue<U>(int oracleColumn_Id)
      if (OracleUdt.IsDBNull(connection, pUdt, oracleColumn_Id))
          throw new Exception(errorMessageHead + oracleColumn_Id.ToString()
        else
          return default(U);
      else
        return (U)OracleUdt.GetValue(connection, pUdt, oracleColumn_Id);
SdoGeometry.cs
using System;
using System.Collections.Generic;
using System.Text;
using Siva.Geo;
using Oracle.UdtBase;
namespace Siva.Geo
  [OracleCustomTypeMappingAttribute("MDSYS.SDO_GEOMETRY")]
  public class SdoGeometry : OracleCustomTypeBase<SdoGeometry>
    private enum OracleObjectColumns { SDO_GTYPE, SDO_SRID, SDO_POINT,
SDO_ELEM_INFO, SDO_ORDINATES }
    private decimal? sdo_Gtype;
    [OracleObjectMappingAttribute(0)]
    public decimal? Sdo_Gtype
      get { return sdo_Gtype; }
      set { sdo_Gtype = value; }
    private decimal? sdo_Srid;
    [OracleObjectMappingAttribute(1)]
    public decimal? Sdo_Srid
      get { return sdo_Srid; }
      set { sdo_Srid = value; }
    private SdoPoint point;
    [OracleObjectMappingAttribute(2)]
    public SdoPoint Point
      get { return point; }
      set { point = value; }
    private decimal[] elemArray;
    [OracleObjectMappingAttribute(3)]
    public decimal[] ElemArray
      get { return elemArray; }
      set { elemArray = value; }
    private double[] ordinatesArray;
    [OracleObjectMappingAttribute(4)]
    public double[] OrdinatesArray
      get { return ordinatesArray; }
      set { ordinatesArray = value; }
    [OracleCustomTypeMappingAttribute("MDSYS.SDO_ELEM_INFO_ARRAY")]
    public class ElemArrayFactory : OracleArrayTypeFactoryBase<decimal> {}
    [OracleCustomTypeMappingAttribute("MDSYS.SDO_ORDINATE_ARRAY")]
    public class OrdinatesArrayFactory : OracleArrayTypeFactoryBase<double>
    public override void MapFromCustomObject()
      SetValue((int)OracleObjectColumns.SDO_GTYPE, Sdo_Gtype);
      SetValue((int)OracleObjectColumns.SDO_SRID, Sdo_Srid);
      SetValue((int)OracleObjectColumns.SDO_POINT, Point);
      SetValue((int)OracleObjectColumns.SDO_ELEM_INFO, ElemArray);
      SetValue((int)OracleObjectColumns.SDO_ORDINATES, OrdinatesArray);
    public override void MapToCustomObject()
      Sdo_Gtype = GetValue<decimal?>((int)OracleObjectColumns.SDO_GTYPE);
      Sdo_Srid = GetValue<decimal?>((int)OracleObjectColumns.SDO_SRID);
      Point = GetValue<SdoPoint>((int)OracleObjectColumns.SDO_POINT);
      ElemArray =
GetValue<decimal[]>((int)OracleObjectColumns.SDO_ELEM_INFO);
      OrdinatesArray =
GetValue<double[]>((int)OracleObjectColumns.SDO_ORDINATES);
SdoPoint.cs
using System;
using System.Text;
namespace Siva.Geo
  [OracleCustomTypeMappingAttribute("MDSYS.SDO_POINT_TYPE")]
  public class SdoPoint : OracleCustomTypeBase<SdoPoint>
    private double? x;
    [OracleObjectMappingAttribute("X")]
    public double? X
      get { return x; }
      set { x = value; }
    private double? y;
    [OracleObjectMappingAttribute("Y")]
    public double? Y
      get { return y; }
      set { y = value; }
    private double? z;
    [OracleObjectMappingAttribute("Z")]
    public double? Z
      get { return z; }
      set { z = value; }
      SetValue("X", x);
      SetValue("Y", y);
      SetValue("Z", z);
        X = GetValue<double?>("X");
        Y = GetValue<double?>("Y");
        Z = GetValue<double?>("Z");
while inserting use dbtype as object
Create one object for sdo
private static Geo.SdoGeometry _sdoGeometry;
        public Geo.SdoGeometry SdoGeometry
            get { return _sdoGeometry; }
            set { _sdoGeometry = value; }
this.Dbm.AddOracleParameters(P_ + TblEnumerationblock.FN_GEOMETRY,
this.TblEnumerationblock.SdoGeometry, OracleDbType.Object,
ParameterDirection.Input);
if (OracleDbType == OracleDbType.Object)
                    this.Oracleparameter.UdtTypeName = "MDSYS.SDO_GEOMETRY";
                this.Oracleparameter.Direction = paramDirection;
View this message in context: http://osgeo-org.1803224.n2.nabble.com/create-redline-line-and-polygon-using-king-fdo-and-MGOS-tp5039612p5058530.html
