[mapguide-users] Measuring distances mismatch
Andy Morsell amorsell at spatialgis.com
Wed May 19 12:04:03 EDT 2010
I'm seeing the same problem in a Fusion layout with MGOS 2.1.  My coordinate
system is a State Plane coordinate system with units of feet and it is set
correctly in the map definition.  I also have units of feet set in the
application definition but it still reports distances (and areas) in some
other unit resulting in huge values.  I dug around the measure widget code
to see if I could find the problem but did not get very far.
Andy Morsell, P.E.
Spatial Integrators, Inc.
47° 46' N 116° 49' W
www.SpatialGIS.com
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jose Cerrejon
Sent: Wednesday, May 19, 2010 2:46 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Measuring distances mismatch
I can't get measure tool works correctly.
I need measure distances in meters with coord. system EPSG:23030, but the
distances are measured incorrectly.
real distance: 2276 m
obtained distance: 5690617 m
The Map resource is set to EPSG:23030. The ApplcacionDefinition have the
<Units> tag set to meters.
What's wrong?
View this message in context:
http://osgeo-org.1803224.n2.nabble.com/Measuring-distances-mismatch-tp507417
5p5074175.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
