[mapguide-users] RE: Measuring distances mismatch
Berdel, Brian
brian.berdel at mcmtrans.com
Thu May 20 13:11:08 EDT 2010
Mike is right about this...Now I remember I did have to specify a projection...
In svn I think you need to use fusion.js rather than fusionSF.js
Brian
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jose Cerrejon
Sent: Thursday, May 20, 2010 11:10 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] RE: Measuring distances mismatch
Thks Mike for this information about ProjectionDef. Unfortunatelly, the
Proj4js in the Mapguide throw me the next error (Firebug): Proj4js is not
defined on line 61088 from fusionSF.js.
My projection is:
<ProjectionCode>EPSG:23030</ProjectionCode>
<ProjectionDef>+proj=utm +zone=30 +ellps=intl +units=m
+no_defs</ProjectionDef>
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Measuring-distances-mismatch-tp5074175p5080114.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
Important notice to recipients:
Copies of documents that may be relied upon by you are limited to the printed copies (also known as 'hard copies') that are signed and sealed by the Engineer and/or Land Surveyor. Files in electronic formats, or other types of information furnished by the Engineer and/or Land Surveyor to you such as text, data or graphics are for your convenience only. Any conclusions or information obtained or derived from such electronic files will be at the user's sole risk. When transferring documents in electronic formats, the Engineer and/or Land Surveyor makes no representation as to long-term compatibility, usability, or readability of the documents resulting from the use of software application packages, operating systems or computer hardware differing from those used by McMahon Associates, Inc. at the beginning of the project.
