[mapguide-users] Mg Server often comes down
Dave Wilson dave.wilson at autodesk.com
Fri May 21 12:30:43 EDT 2010
The version you are using is old and missing many improvements for stability.
What data types are used in your map: SDF, Raster...etc
We need way more information before anyone can suggest anything other than upgrade.
If the server crashes is there a stack trace or do you get a segmentation fault with no information?
Is the server running out of memory?
Regards,
Dave
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of swap
Sent: Friday, May 21, 2010 9:43 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Mg Server often comes down
I made a develpment for using mgos, now it is being published, but when
several users acces the server downs, it is necesary to restart for
continue.
I reviwed posts and found this matter some times no resolved, I'm looking
for some advice to avoid the server crash, different of update or reinstall
the server, due it was very hard.
Enviroment
OS REHL 4.8
mgos 2.0.2
FDO 3.3.0
Maestro 2.0
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Mg-Server-often-comes-down-tp5084855p5084855.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
