[mapguide-users] Setting Initial Map Selected object
Mike Adair madair at dmsolutions.ca
Tue May 25 10:11:08 EDT 2010
Jason is correct that this isn't in the Fusion SVN yet but it
essentially just parsed the URL query params and then does a map query
on the Fusion MAP_LOADED event like so:
    doStartup: function() {
        this.mapWidget.deregisterForEvent(Fusion.Event.MAP_LOADED,
this.doStartupFn);
        if (this.startup.spatialfilter != '' || this.startup.filter != '') {
            var options = {
              layers: this.startup.selectlayer,
              geometry: this.startup.spatialfilter,
              filter: this.startup.filter,
              queryHiddenLayers: true,
              zoomTo: true
            this.mapWidget.query(options);
I can put that into Fusion but not for a few weeks now.  Contributions
are welcome however as a ticket in the Fusion Trac system.
Mike
Jason Birch wrote:
> DMSG did something like this for our implementation. I think it may be
> at the application level rather than in Fusion core, but not sure...
>  http://maps.nanaimo.ca/nanaimomap/?filter=(GISLINK%3D116707)&selectlayer=AssessmentParcels
> Jason
> On 2010-05-24, Jose Cerrejon <gis at mapas-sll.com> wrote:
>> I see the ?extent url feature, so maybe is the same. Where is implemented
>> this feature (files)?
>> View this message in context:
>> http://osgeo-org.1803224.n2.nabble.com/Setting-Initial-Map-Selected-object-tp5093643p5093718.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
   Michael Adair
   Senior Software Architect
   DM Solutions Group Inc.
   Office: (613) 565-5056 x26
   http://www.dmsolutions.ca
   http://research.dmsolutions.ca
