[mapguide-users] Re: create redline line and polygon using king fdo and MGOS
Tony techswami at hotmail.com
Wed May 26 14:21:35 EDT 2010
thanks so much for explination. i guess i was cinfused.
just to giyou FYI. i  have a running app where i an using the SDF to create
a readline. whe i try the same logic with king fdo or autodesk fdo for
oracle . it did not work. i could not write the geometry to the  feature
sorce.
may be  I am not doing it correctly. do you have any sample for the same (
to implement FDO/KingOra) for creating polygon or line in oracle  using
mgos.
thanks
Tony
View this message in context: http://osgeo-org.1803224.n2.nabble.com/create-redline-line-and-polygon-using-king-fdo-and-MGOS-tp5039612p5105039.html
