[mapguide-users] Fusion single file build
Mike Adair
madair at dmsolutions.ca
Thu May 27 09:10:15 EDT 2010
Changing the subject to something more appropriate.
The difference between using the AppDef in the single file build is that
without it, we don't know beforehand what widgets will be used so all of
them get included in the single file. If you do point to your
application's AppDef, it will parse that and include only the widget
code that will be used in the app, resulting in a slightly smaller file
size. In addition, it will convert the AppDef XML file into a JSON
structure and include that in the file as well, saving some additional
time at application startup because loading and converting the file has
already been done.
Mike
Jose Cerrejon wrote:
> Jorge Soria wrote:
>> Thanks Jose.
>> Can I make a build of my fusionSF.js from the Mapguide Open Source I have
>> installed at my server???
>> If I try to build it with Apache Ant, what is the
>> ApplicationDefinition.xml I have to take? The one that is with my
>> template? Then the generated fusionSF.js will have the projection I
>> defined at the <ProjectionDef> in the xml?
> Read
> http://osgeo-org.1803224.n2.nabble.com/RE-Compiling-fusionSF-js-td5084114.html#a5084114
> this recent threat.
> I think you have to build from the SVN. It's not neccesary to link the
> ApplicationDefinition.xml file. This file is taken from your website.
Michael Adair
Senior Software Architect
DM Solutions Group Inc.
Office: (613) 565-5056 x26
http://www.dmsolutions.ca
http://research.dmsolutions.ca
