[mapguide-users] GetSpatialContext for FeatureSource
Zac Spitzer
zac.spitzer at ennoble.com.au
Thu May 27 22:54:52 EDT 2010
that's a nasty one... you might want to try resaving the feature source
ie get and set the resourcecontent which should flush any caching,
this works at least for cached oracle schemas and I reckon it
might work for you...
definately worthy of filing a bug in trac, check first that there
isn't one already filed
http://trac.osgeo.org/mapguide/query?status=new&status=assigned&status=reopened&group=component&order=priority
z
On 28 May 2010 01:08, Dave Wilson <dave.wilson at autodesk.com> wrote:
> I believe this is an issue and I'm not sure there is a fix.
> Regards,
> Dave
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Gunter Becker
> Sent: Thursday, May 27, 2010 7:27 AM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] GetSpatialContext for FeatureSource
> Hi,
> I have a FeatureSource which I create at runtime in the Session-Repository.
> I insert and delete features in this FeatureSource several times and each
> time I want to zoom to the full extent of the FeatureSource.
> Unfortunately, the GetSpatialContext methode of the FeatureService returns
> the right extent for the FeatureSource only the first time it is requested.
> When I add features to this FeatureSource which are outside of this extent
> the GetSpatialContext methode always return the same extent.
> So, I suppose the extent of the FeatureSource is cached somewhere.
> Can anyone confirm this behaviour! Is there a methode to set the
> FeatureSource to the right extent?
> Something like a refresh methode for FeatureSources?
> Thanks, Gunter
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/GetSpatialContext-for-FeatureSource-tp5108554p5108554.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
