[mapguide-users] Re: How to render MgMultiGeometry
Zac Spitzer zac.spitzer at ennoble.com.au
Mon May 31 20:58:54 EDT 2010
i remember someone posting a few screen shots about this a while ago
ideally the provider should either throw an exception or handle this properly
I'm not even sure if other providers work ( and mapguide generally )
with collections?
On 1 June 2010 03:33, djonio <DJonio at miami-airport.com> wrote:
> Gunter,
> I am using KingOra(8.15)
> It looks to me like _COLLECTION_ type geometry is not supported or not
> working(I probably should know but do not). I managed to find an Oracle 10g2
> object:
> MDSYS.SDO_GEOMETRY(2004,2236,null,MDSYS.SDO_ELEM_INFO_ARRAY(1,2,1,5,1003,1),MDSYS.SDO_ORDINATE_ARRAY(893387.1279764,530499.1798361,893387.2056353,530499.1405861,893371.6056161,530536.2878878,893359.8797596,530513.1144291,893381.936952,530501.8403549,893386.3799577,530510.5328853,893391.6481135,530507.8401773,893387.2056353,530499.1405861,893388.317921,530498.5784176,893418.2134005,530483.2911693,893427.7218373,530501.8030188,893423.6081282,530503.9056561,893426.9076444,530510.3610015,893389.362765,530529.5512911,893388.414628,530527.6963068,893371.6056161,530536.2878878))
> Validated w/SDO_GEOM.VALIDATE_GEOMETRY_WITH_CONTEXT and it is fine.
> fdo2fdo (7.15) does not like it at all. He just gives up.
> Utilizing MGOS 2.1, FDO inserts the record into the table/featuresource sans
> geometry however.
> I again verified that all works well with what Oracle calls the
> MULTIPOLYGON.
> This is certainly not a critical issue for us but thought I would pass it
> on.
> r,
> dennis
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/How-to-render-MgMultiGeometry-tp5112715p5122638.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
