[mapguide-users] Re: Calculating map meters per unit without MgCoordinateSystem
Zac Spitzer zac.spitzer at gmail.com
Mon Nov 8 09:13:57 EST 2010
I had this problem with using MG with openlayers too.
Solution would be a new http method which returns a json config document
which covers everything required, MPU, extent scales etc for a given map def
z
On Tue, Nov 9, 2010 at 12:18 AM, Jackie Ng <jumpinjackie at gmail.com> wrote:
> Well that makes the Rendering Service API mostly useless for client-side
> created runtime maps :(
> The workaround is of course knowing the actual meters-per-unit value
> beforehand when creating the runtime map client-side, but "workaround" is a
> far too generous a word to describe that!
> - Jackie
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Calculating-map-meters-per-unit-without-MgCoordinateSystem-tp5709001p5716813.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
