[mapguide-users] Re: Layer from view beomes unselectable
Ivan Miličević
Ivan.Milicevic at supranet.hr
Mon Nov 15 21:42:14 EST 2010
Hello,
I had same problem, please find out solution in this blog post: http://themapguyde.blogspot.com/2010/08/using-fdo-schema-overrides.html
You need to create XML config file for MSSQL dana connection. Bo noticed that new version of FDO toolbox has been improved and defining primary key in views is much easier (described in this blog post: http://themapguyde.blogspot.com/2010/09/using-fdo-schema-overrides-redux.html )
Have a nice day.
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Sean Gibson
Sent: Monday, November 15, 2010 8:49 PM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Re: Layer from view beomes unselectable
I have OID, which is the primary key in the original table. I made sure this is checked in the view.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Layer-from-view-beomes-unselectable-tp5741188p5741226.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
