[mapguide-users] Coordinate system problem validating a map
Klaus Leth Pedersen klpe at aarhus.dk
Thu Nov 18 07:51:22 EST 2010
I have a datasource from a MapInfo .tab file, when I check the coordinate
system in MapInfo it says ETRS89.UTM-32N (ESPG 25832). The map that uses
the datasource is set to the same coordinatsystem, but when I validate the
map in Maestro Version 2.1.4.5245 I get a warning that the server uses
resources to transform the coordinatsystem how can that be when the two
coordinatesystems are the same ?
My mapguide server by the way is a Mapguide opensource 2.2 beta
 Thank you.
 Klaus Pedersen
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20101118/0c85ff77/attachment.html
