[mapguide-users] Re: Is it possible to pass data from the map to
the printable page?
Jackie Ng
jumpinjackie at gmail.com
Mon Nov 22 21:20:25 EST 2010
You can take the existing printablepage and printablepageui files in your
AJAX viewer (used by the print command), modify them to suit your needs.
Then create a new InvokeURL command that links to your modified
printablepageui file.
- Jackie
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Is-it-possible-to-pass-data-from-the-map-to-the-printable-page-tp5747316p5765236.html
