[mapguide-users] Re: Create feature source
VOLZ Mark (FN)
Mark.Volz at ergon.com.au
Tue Nov 23 23:47:48 EST 2010
Lee,
I'm using this in Autocad map which means a lot of the class names are
different but they are basically they are the same you just need to
replace the AcMap<class> with Mg<class>
AcMapResourceService rs;
rs =
AcMapServiceFactory.GetService(MgServiceType.ResourceService) as
AcMapResourceService;
AcMapFeatureService fs;
fs =
AcMapServiceFactory.GetService(MgServiceType.FeatureService) as
AcMapFeatureService;
FeatureSourceType fstype = new
FeatureSourceType();
//show loading form
Loading loadform = new Loading();
loadform.StartPosition =
FormStartPosition.CenterScreen;
loadform.Text = "connecting to " + fdo;
Autodesk.AutoCAD.ApplicationServices.Application.ShowModelessDialog(load
form);
//create the connection
string xmlstring = null;
MgResourceIdentifier fsId = new
MgResourceIdentifier(librarypath);
//set fdo details
fstype.Provider = fdo;
NameValuePairType param1 = new
NameValuePairType();
param1.Name = "Password";
param1.Value = fdo_password;
NameValuePairType param2 = new
param2.Name = "Service";
param2.Value = datasource;
NameValuePairType param3 = new
param3.Name = "Username";
param3.Value = fdo_user;
NameValuePairType param4 = new
param4.Name = "DataStore";
param4.Value = para1;
NameValuePairType param5 = new
param5.Name = "LongTransaction";
param5.Value = para2;
fstype.Parameter = new NameValuePairType[] {
param1, param2, param3, param4, param5 };
//serialize the featuresource object model to
xml string
using (StringWriter writer = new StringWriter())
XmlSerializer xs = new
XmlSerializer(fstype.GetType());
xs.Serialize(writer, fstype);
xmlstring = writer.ToString();
//convert unicode string to utf8 bytes for
resource service
byte[] unicodeBytes =
Encoding.Unicode.GetBytes(xmlstring);
byte[] utf8Bytes =
Encoding.Convert(Encoding.Unicode, Encoding.UTF8, unicodeBytes);
//create byte reader of xml feature source def.
& store in repository
MgByteSource XmlSource = new
MgByteSource(utf8Bytes, utf8Bytes.Length);
try
rs.SetResource(fsId, XmlSource.GetReader(),
null);
fs.DescribeSchema(fsId, para1);
loadform.Dispose();
catch (MgException ex)
MessageBox.Show("error creating " + fdo + "
connection. \nError reads:\n" + ex);
The real trick with the autodesk Fdo is the LongTransaction parameter if
you are not using oracle workspaces (oracle versioning) simply set this
to Live if you are using workspaces let me know and I can run through
how to find a version.
Hope this helps.
Mark
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Lee
Sent: Wednesday, 24 November 2010 2:33 PM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Re: Create feature source
Thanks Mark, I am using Autodesk FDO. I would really appreciate some
example c# .net code would help me a lot.
Lee
View this message in context:
http://osgeo-org.1803224.n2.nabble.com/Create-feature-source-tp5768882p5
769213.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
To report this email as spam, please forward to spam at mailcontrol.com
This e-mail (including any attachments) may contain confidential or
privileged information and is intended for the sole use of the person(s) to
whom it is addressed. If you are not the intended recipient, or the person
responsible for delivering this message to the intended recipient, please
notify the sender of the message or send an e-mail to
mailto:help.desk at ergon.com.au immediately, and delete all copies. Any
unauthorised review, use, alteration, disclosure or distribution of this
e-mail by an unintended recipient is prohibited. Ergon Energy accepts no
responsibility for the content of any e-mail sent by an employee which is of
a personal nature.
Ergon Energy Corporation Limited ABN 50 087 646 062
