[mapguide-users] Re: Directory structure and performance
Jackie Ng jumpinjackie at gmail.com
Thu Nov 25 05:03:49 EST 2010
Performance is only a problem if you need to do a full listing of the
repository.
Maestro only request listings one level deep as you expand each folder node
for the first time.
Direct resource access by resource id lookup should not be affected by
folder structure. Resource access by resource id lookup should be the same
regardless of whether the resource is 2 folders or 20 folders deep.
- Jackie
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Directory-structure-and-performance-tp5773513p5773610.html
