[mapguide-users] RE: Linux distributions tested for MapGuide
Trevor Wekel trevor_wekel at otxsystems.com
Wed Oct 6 12:33:49 EDT 2010
Hello,
Anything using GCC 4.1 should be ok from a compilation perspective.  MapGuide compiles natively on CentOS 5 and the CentOS 5 binaries work on Ubuntu 9.  OpenSuse 10 should be fine for native compilation.  Binaries built on OpenSuse 10 may work in on OpenSuse 11.
Regards,
Trevor
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Fernandez-de La Pradilla Dueñas, Elena
Sent: October 6, 2010 2:57 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] RE: Linux distributions tested for MapGuide
Good morning
Experts, i need your help.
I would like to know what   Linux distributions have been  tested in MapGuide  Open Source.
I have  seen  Red Hat  4.0 and Fedora into the web page  but this information  is dated in 2006.
Has Suse Linux been  tested for MapGuide recently?
If you have any question dont hesitate to ask.
Thank you very much and Best Regards
Elena
Elena Fernández de la Pradilla
Arquitectura y Tecnología
Tf: 62559805
Este mensaje de correo electronico y sus documentos adjuntos estan dirigidos EXCLUSIVAMENTE a los destinatarios especificados. La informacion contenida puede ser CONFIDENCIAL y/o estar LEGALMENTE PROTEGIDA y no necesariamente refleja la opinion de ENDESA. Si usted recibe este mensaje por ERROR, por favor comuniqueselo inmediatamente al remitente y ELIMINELO ya que usted NO ESTA AUTORIZADO al uso, revelacion, distribucion, impresion o copia de toda o alguna parte de la informacion contenida. Gracias.
This e-mail message and any attached files are intended SOLELY for the addressee/s identified herein. It may contain CONFIDENTIAL and/or LEGALLY PRIVILEGED information and may not necessarily represent the opinion of ENDESA. If you receive this message in ERROR, please immediately notify the sender and DELETE it since you ARE NOT AUTHORIZED to use, disclose, distribute, print or copy all or part of the contained information. Thank you.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20101006/380389a5/attachment.html
