[mapguide-users] Re: Attempted to read or write protected memory. This is often an indication that other memory is corrupt.
Birgir bgu at geograf.dk
Thu Oct 7 05:40:17 EDT 2010
Ive tried to put the bin folder to system path with the same results.
When I tried to add WebUnmanagedApi.dll with regsvr32.exe I got this
message:
LoadLibrary("d:\.....\WebUnmanagedApi.dll") failed - The specific procedure
could not be found.
is it possible that regsvr32.exe fails because WebUnmanagedApi.dll is a
dependent of another dll (osgeo.mapguide.web.dll) ?
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Attempted-to-read-or-write-protected-memory-This-is-often-an-indication-that-other-memory-is-corrupt-tp5603440p5610649.html
