[mapguide-users] Problem to show properties in Ajax viewer with
ver. 2.2.0.5197
dan.nilsson at tyrens.se
Thu Oct 7 09:10:03 EDT 2010
I have installed MapGuide ver. 2.2.0.5197 on a XP Professional version 2002
SP3, with IIS.
I selected .Net development at the installation. I have a layer with a SDF
file connection, select all (or just one) properties to be available in
viewer when I auther the layer. Make a Map with the layer, and show the map
on a weblayout (Ajax). When I show the layout in Internet Explorer 8, log in
as Administrator, select one object on the map, I don't se any properties
information in the layout, I get a error message like this
"User Agent: Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 5.1; Trident/4.0;
.NET CLR 2.0.50727; .NET CLR 3.0.04506.648; .NET CLR 3.0.4506.2152; .NET CLR
3.5.30729; .NET CLR 1.1.4322; InfoPath.2)
Timestamp: Thu, 7 Oct 2010 13:00:27 UTC
Message: Unterminated string constant
Line: 3886
Char: 9
Code: 0
URI:
http://localhost/mapguide/mapviewerajax/mapframe.aspx?MAPDEFINITION=Library%3a%2f%2fKristianstad%2fMaps%2fTest.MapDefinition&TYPE=HTML&SHOWLEGEND=1&SHOWPROP=1&INFOWIDTH=200&LOCALE=en&HLTGT=1&HLTGTNAME=&SHOWSLIDER=1&SESSION=c31ee770-d212-11df-8000-000c29df66ac_en_7F0000010AFC0AFB0AFA
What have I done wrong? Is it a bug in 2.2 version?
It works fine in 2.1 version.
Dan
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Problem-to-show-properties-in-Ajax-viewer-with-ver-2-2-0-5197-tp5611272p5611272.html
