[mapguide-users] Re: Problem to show properties in Ajax viewer with ver. 2.2.0.5197
Jackie Ng jumpinjackie at gmail.com
Fri Oct 8 05:50:16 EDT 2010
IIS >= 6.0 is a supported configuration, but you mentioned Windows XP, so
unless your running the 64-bit edition of XP, that version of IIS is
actually 5.1 and I haven't touched or tested on that version of IIS for a
while now nor do I know if that version is still even supported.
- Jackie
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Problem-to-show-properties-in-Ajax-viewer-with-ver-2-2-0-5197-tp5611272p5614380.html
