[mapguide-users] Re: data porting
T.kiran kumar reddy kiranreddy.hcu at gmail.com
Tue Oct 12 05:08:27 EDT 2010
Thanks for your reply. i think when we are using the autocad map 3d to
convert dwg to shp it can't come as a single file. for points it creates one
shp , for lines one and for plolygons it create one. so every dwg becomes
three shp files through that. Is there any other alternative way? if not dwg
file ,if you know how to do same(conversion of the dxf to sqlserver 2008)
for dxf please give the suggesitions
View this message in context: http://osgeo-org.1803224.n2.nabble.com/data-porting-tp5601887p5625935.html
