[mapguide-users] Re: Expression Editor in Maestro
Nimrod Cnaan nimcnaan at hotmail.com
Thu Oct 14 15:27:17 EDT 2010
Thanks Jackie,
1. Is it possible to set a DefaultValue for a date property - say "CURRENTDATE( )"
2. There is a bug in the Maestro - when deleting @DISPLAY String, after assigning it, in the "Properties Available in the viewer":
=>> after saving the LayerDef the layer is not selectable in the map - because - the LayerDef XML's  structure is not legal
> Date: Wed, 6 Oct 2010 16:18:23 -0700
> From: jumpinjackie at gmail.com
> To: mapguide-usersate at lists.osgeo.org
> Subject: [mapguide-users] Re: Expression Editor in Maestro
> Take a look at the docs on the Expression Builder for AutoCAD Map.
> http://docs.autodesk.com/MAP/2011/ENU/AutoCAD%20Map%203D%202011%20Help/Map3D_2011_HTML_Help/filesExpressionBuilder/WS73099cc142f48755-e1f2279115824679ea-7f1d.htm
> Both are editors for the same expression language.
> - Jackie
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Expression-Editor-in-Maestro-tp5606970p5609366.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20101014/176229f6/attachment.html
