[mapguide-users] Update SHP properties
sekko970 fabio.franceschini at techneteam.it
Mon Oct 18 05:59:37 EDT 2010
I need to update the properties of objects in a shapefile.
I select an object using a filtered FeatureReader, and update each property.
It works fine for each property type, but not when a property has type
"Decimal":
in this case FeatureReader get the type MgPropertyType.Double, so I set an
MgDoubleProperty, but the new value is not saved and no exceptions are
returned.
I'm using MG 2.0.2.
Dim query As New MgFeatureQueryOptions()
query.SetFilter(filter)
featureReader = featureSrvc.SelectFeatures(myFeatureSourceId,
myFeatureClassName, query)
featureReader.ReadNext()
Dim mgProps As New MgPropertyCollection
For p As Integer = 0 To featureReader.GetPropertyCount - 1
    Dim mgProp As MgProperty = Nothing
    Select Case
featureReader.GetPropertyType(featureReader.GetPropertyName(p))
        Case MgPropertyType.Double
            mgProp = New MgDoubleProperty(k, CType(newValue, Double))
    End Select
    mgProps.Add(mgProp)
Next
featureReader.Close()
Dim commands As New MgFeatureCommandCollection()
commands.Add(New MgUpdateFeatures(myClassName, mgProps, filter))
Call featureSrvc.UpdateFeatures(myFeatureSourceId, commands, False)
Thanks,
Fabio
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Update-SHP-properties-tp5646451p5646451.html
