[mapguide-users] Re: Inserting features in PostGIS fails
ar_gaeta
ar_gaeta at yahoo.it
Mon Oct 18 12:04:49 EDT 2010
I'm still using the OsGeo.PostGIS provider version 3.4.
I will install the new version as soon as I can.
My problem is really too deep: I have all the example-files provided by
Autodesk in .php (like in the Developer's guide), but I'm working with Java,
and I don't know very well both languages.
My final goal is to allow on-line editing to the feature sources.
I've read the guide "Editing Data Online with the Autodesk MapGuide
Enterprise API" by Dongjin Xing, but I lose myself somewhere...
Could I ask you a pleasure? I've written this code in .jsp just to delete a
simple polygon feature from a SDF file called "area", based on the attribute
"name = 'primo'".
But something is wrong it seems I'm not able to "communicate" with the site.
Could you give it a look please? It's an application that I would like to
start from the task pane:
String sessionId = request.getParameter("SESSION");
String mapName = request.getParameter("MAPNAME");
MapGuideJavaApi.MgInitializeWebTier(webconfigFilePath);
// Get the user information using the session id,
// and set up a connection to the site server.
MgUserInformation userInfo = new MgUserInformation(sessionId);
MgSiteConnection siteConnection = new MgSiteConnection();
siteConnection.Open(userInfo);
MgSite site = new MgSite();
site.Open(userInfo);
// Get an instance of the required service(s).
MgResourceService resourceService = (MgResourceService)
siteConnection.CreateService(MgServiceType.ResourceService);
MgMap map = new MgMap();
map.Open(resourceService, mapName);
MgFeatureService featureService =
site.CreateService(MgServiceType.FeatureService) as MgFeatureService;
String featureSourceName = "Session:sessionId//area.FeatureSource";
//MgResourceIdentifier fdo = new
MgResourceIdentifier("Library://prova_basic/Data/area.FeatureSource");
MgResourceIdentifier fdo = new MgResourceIdentifier(featureSourceName);
MgDeleteFeatures deleteFeature1 = new
MgDeleteFeatures("area","nome='primo'");
MgFeatureCommandCollection commands = new MgFeatureCommandCollection();
commands.Add(deleteFeature1);
//MgLayer layer = map.GetLayers().GetItem("area");
//layer.UpdateFeatures(commands);
featureService.UpdateFeatures(fdo, commands, false);
Thanks for your answer, and thanks also for your blog and your availability.
Riccardo
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Inserting-features-in-PostGIS-fails-tp1813557p5647593.html
