[mapguide-users] King Oracle won't read all features from Oracle
Zac Spitzer zac.spitzer at gmail.com
Wed Oct 20 21:48:35 EDT 2010
the lack of transactions is a known issue, you can you the
batchcollection updates for that
also, try using the latest version available here
http://www.sl-king.com/fdooracle/fdooracle.html
if 2) is still a problem, are can you able to generate a sample map
and dataset which
reproduces the problem?
z
On Thu, Oct 21, 2010 at 12:42 PM, Mauricio Villablanca
<mgvillablanca at yahoo.com> wrote:
> I used King Oracle with Mapguide OS 1.2 quite a while and due to its bugs, I
> decided to use Mapguide Enterprise 2009 that has a more robust Oracle
> provider.
> Now I need to deploy MGOS 2.1 with King Oracle and I have noticed the
> following:
> 1) it won't support long transactions
> 2) the features for some connections won't display in the map (0-infinity
> range, layer set to visible).
> I though #2 would be a consequence of #1 but some of the datastores King
> Oracle won't display any data for have very minimal data, at most 200 rows.
> I wrote a script that reads the features of the layer and it works so the
> data is there. The features are just not displayed.
> Is anybody having the same problem? I'm using the 3.1.0.R000 version
> (included in MGOS 2.1).
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/King-Oracle-won-t-read-all-features-from-Oracle-tp5657213p5657213.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
