[mapguide-users] Re: Problem connecting GeoREST to MapGuideOS 2.2
RC1
Haris Kurtagic
haris at sl-king.com
Thu Oct 21 08:01:05 EDT 2010
I don't see clearly from your email what you are entering in restcfg.xml.
In georest documentation there are samples how you define MG Layers as
source of your data.
http://code.google.com/p/georest/wiki/Configuration
Like:
<Source type="MapGuide">
<FeatureSource>Library://Samples/Sheboygan/Data/Parcels.FeatureSource</FeatureSource>
<FeatureClass>SHP_Schema:Parcels</FeatureClass>
<ServerIp>192.168.0.33</ServerIp>
<ServerPort>2812</ServerPort>
</Source>
On the doc page there is also sample for kml representation
Like:
<Representation renderer="Template" pattern=".kml"
mimetype="application/vnd.google-earth.kml+xml" >
pattern defines string which is used to recognize which representation
is requested from URI. Like: http://yourserver/rest/sheboygan/1.kml
Could be .xml .html, .json,..., .xxx - whatever you define in
<Representation pattern=".xxx". It is up to you.
What you enter as "mimetype" is included in georest http response as
content type .
Trough using Templates you can define basically any type of text-based
response. Atom, GeoRSS, KML, XML, etc..
In order for URI to be recognized by GeoRest and response recognized
by client "pattern" and "mimetype" are used.
Haris
On Thu, Oct 21, 2010 at 1:43 PM, Clonus <biogest at gmail.com> wrote:
> *I have MapguideOS 2.2 with PostGIS database (Windows 2003). 1. The
> configuration in the file restcfg.xml is
> Library://comunal/database/villarrica.FeatureSource public_Schema:vial
> 192.168.1.2 8008 Is correct this value to FeatureClass?? 2. In the line of
> Representation: that values are pattern and mimetype?? thanks for helping
> me! Clonus
> ________________________________
> View this message in context: Re: Problem connecting GeoREST to MapGuideOS
> 2.2 RC1
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
