[mapguide-users] Re: (1092688208) Resource was not found:
Library://Samples/Layouts/Sample.WebLayout
everling
tceverling at yahoo.co.uk
Fri Oct 22 08:53:03 EDT 2010
I have noticed that under some strange circumstances, exports may be
invisible to running applications despite manually and successfully testing
the variable before and after executing the application.
I just encountered the same problem here and resolved this by copying the
export lines into the "/etc/environment" and then relogin before starting
the server. I hope this helps you.
For the curious, the default value of
"/opt/Autodesk/mapguideenterprise2010/share/gis/coordsys" was set in
"MgDev/Common/CoordinateSystem/CoordSysCatalog.cpp" on line 227. And the
error message came from line 240 of the same file.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/1092688208-Resource-was-not-found-Library-Samples-Layouts-Sample-WebLayout-tp4780445p5662411.html
