[mapguide-users] Re: Tiled Maps and Fusion - revisited
Wilson Herrera wherrera at pccadpanama.com
Fri Oct 22 09:49:26 EDT 2010
i think the trouble comes from the fact that the overview map uses the
getmapimage action in the mapagent, so this behavior is the same as printing
( is the same call), if you can get mapagent to include the google layers,
then the problem is fixed.
this of course is just the result of a quick view of the code, so i may be
terribly wrong but you cannot deny that the same thing happens when you try
to print.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Tiled-Maps-and-Fusion-revisited-tp5649456p5662608.html
