[mapguide-users] URL Parameters
Jason Birch
jason at jasonbirch.com
Fri Oct 22 16:29:07 EDT 2010
You might be better off asking on the fusion list. Show/hide groups is
broken too in my experience, I think because of timing issues.
On 2010-10-22, GordonL <gordon.luckett at arrowgeomatics.com> wrote:
> Using the Fusion URL Parameters you can do quite a lot.
> - choose the default extents of the map ?extents=-118,45,-117,46
> - choose the map (using patch http://trac.osgeo.org/fusion/ticket/65)
> &mgmapresourceid=Library://Maps/myMap.MapDefinition (this might be called
> "theme" now)
> -choose the Web Layout
> Some other URL parameters are showgroups/hidegroups/showlayers
> I love the URL parameters because you can save/bookmark them.
> Only issue. the hidelayers/showlayers does not update the legend - too bad.
> Is there a fix?
> http://osgeo-org.1803224.n2.nabble.com/URL-Parameters-tp5662444p5662444.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
