[mapguide-users] Re: Mapguide won't display all features fromKing Oracle connections
Jonio, Dennis (Aviation) DJonio at miami-airport.com
Wed Oct 27 07:56:18 EDT 2010
Haris,
Apologies for my poor explanation.
Yes, you did fix gtype=4. Works just fine, DB wise. _MapGuide_ does NOT render 4's. It does render the other multi-gtypes = 5,6 and 7.
Like I said, I have always constructed _circle_ objects as INFO_ARRY(1,1005,1,1,2,2)'s. I was skeptical from the beginning about Oracles _optimized point_ so I make those as INFO_ARRAY(1,1,1) and the Oracle _rectangle_ becomes a INFO_ARRAY(1,1003,1,1,2,1) w/all 5 ordinates.  A couple days ago I experimented w/Function:
 OnCircleDigitized(Circle) {
            r = Circle.Radius;
            p1x = Circle.Center.X + r;
            p1y = Circle.Center.Y + r;
            p2x = Circle.Center.X - r;
            p2y = Circle.Center.Y + r;
            p3x = Circle.Center.X - r;
            p3y = Circle.Center.Y - r;
            p4x = Circle.Center.X + r;
            p4y = Circle.Center.Y - r;
            ords = p1x + "," + p1y + "," + p4x + "," + p4y + "," + p3x + "," + p3y + "," + p2x + "," + p2y + "," + p1x + "," + p1y;
            //tmp = "MDSYS.SDO_GEOMETRY(2003, 2236, NULL, MDSYS.SDO_ELEM_INFO_ARRAY(1,1005,1,1,2,2), MDSYS.SDO_ORDINATE_ARRAY(" +
            //        ords + "))";
            tmp = "MDSYS.SDO_GEOMETRY(2003, 2236, NULL, MDSYS.SDO_ELEM_INFO_ARRAY(1,1003,4), MDSYS.SDO_ORDINATE_ARRAY("
                    + p1x + "," + p1y + "," + p2x + "," + p2y + "," + p3x + "," + p3y +
            var geometryInput = document.getElementById("currentscribblegeometryInput");
            geometryInput.value = tmp;
            tmp_control = document.getElementById("sessionName");
            SESSION = tmp_control.value;
            tmp_control = document.getElementById("mapName");
            MAPNAME = tmp_control.value;
            tmp_control = document.getElementById("textForFeature");
            TEXT = tmp_control.value;
            tmp_control = document.getElementById("currentscribbleText");
            tmp_control.value = TEXT;
            MiMethodsMgr.InsertUserSessionFeature(SESSION, MAPNAME, TEXT, 0, geometryInput.value,
                                OnCompleteUserSessionInsertMethod, OnError_Generic, OnTimeOut_Generic);
And found that my _ORACLE circles_ were _Oraclewise_ valid BUT I get the _failed to stylize-my bad_ error in the log and the layer does not render.
As a side note FDO Toolkit fails to read a table w/a Oracle _circle_. (By the way, I do this insert via OracleConnection NOT MapGuide/FDO. I must do validity checking before the insert. So if there is/was an issue I would not have seen it here.)
I hope I have done a better job in explaining? I am very, very pleased w/KingOra. Oracle itself has done a poor job in explaining that Oracle Locator is all that is required to do the basics and it is totally FREE. With the sheer weight of Oracle's experience w/geometry objects I certainly believe you have hit the mark w/this provider! Kudoes to you!!!
Haris, IMHO, there is absolutely NO advantage in storing INFO_ARRAY(1,1003,4)'s over INFO_ARRY(1,1005,1,1,2,2)'s.
r,
dennis
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Haris Kurtagic
Sent: Tuesday, October 26, 2010 1:32 PM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] Re: Mapguide won't display all features fromKing Oracle connections
I forgot a bit, but haven't I fixed some gtype 4 after you send me
test geometries ?
If there are gtype 4 geometries you think King.Oracle can't read, send
them please, I will check it
Haris
On Tue, Oct 26, 2010 at 1:37 PM, djonio <DJonio at miami-airport.com> wrote:
> Howdy,
> MGOS 2.1
> KingOra 8.19
> We use KingOracle a bunch and our only issue is and has been mixed
> multi-geometries(collections - sdo_gtype : 4) and circles (1,1003,4). We
> have no issues at all on the FDO/Mg input input side and it appears to me
> that it is an issue with MG rendering. Circles have been a real issue in
> that MG throws one of those "failed to stylize" errors and just gives up.
> The fix for me is to use (1,1005,1, 1,2,2)'s as a couple arcs instead of
> circles. The gtype 4's don't produce the failed to stylize error but they
> silently do not render.
> Since the workaround for circles is relatively easy and the need for the
> collection type geometry is rare for me I have not persued the issue.
> However, if someone wishes to fix this I can produce some EPSG:2236(FL83-EF)
> geometries for test.
> r,
> dennis
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Mapguide-won-t-display-all-features-from-King-Oracle-connections-tp5657213p5674262.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Scan by McAfee
