[mapguide-users] 2.2 RC1 64 bit - unable to build
Berdel, Brian
brian.berdel at mcmtrans.com
Wed Oct 27 13:50:31 EDT 2010
Trying to Build 2.2 RC1 64 bit Project in VS 2010 and keep getting
Could not load file or assembly 'MapGuideDotNetApi' or one of its dependencies. An attempt was made to load a program with an incorrect format. Seems like that would mean these are 32 bit dlls then? I downloaded the 64 bit installer. Anyone else successful with a .net project?
Thanks,
Brian Berdel
McMahon Associates, Inc.
p: 215.283.9444 x 260
www.mcmtrans.com
Important notice to recipients:
Copies of documents that may be relied upon by you are limited to the printed copies (also known as 'hard copies') that are signed and sealed by the Engineer and/or Land Surveyor. Files in electronic formats, or other types of information furnished by the Engineer and/or Land Surveyor to you such as text, data or graphics are for your convenience only. Any conclusions or information obtained or derived from such electronic files will be at the user's sole risk. When transferring documents in electronic formats, the Engineer and/or Land Surveyor makes no representation as to long-term compatibility, usability, or readability of the documents resulting from the use of software application packages, operating systems or computer hardware differing from those used by McMahon Associates, Inc. at the beginning of the project.
